Old 03-01-2011, 04:20 PM   #1
HerYarisNotMine
Drives: '07 Yaris Hatchback
Higher pressures like that will result in stiffer sidewalls...that helps handling, but will cause premature wear on the center of your treads...also, your tires are part of your cushioning and suspension system, so if you make them stiffer, you are transferring shock to your suspension system, which increases wear on it.
Everything is a trade off. If you car is a toy, sure, do any mods you want to increase your pleasure in driving it. But if it's a daily driver, I would follow factory specs for tire pressure. The extra MPG you massage out of it imo isn't worth the reduced traction and additional wear to the suspension.
HerYarisNotMine is offline   Reply With Quote
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 04:54 PM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
