Old 03-01-2011, 10:29 PM   #17
zakerya1
Drives: toyota yaris
The axle moves up quite a bit when the weight of the front compresses the strut. That does mean that if you get the front tires to completely leave the ground that some axle rubbing will occur (when you're doing the Dukes of Hazard jumps). When you lower the car off the the jack or lift, as soon as the tire touches the ground the axle clears the plate below.
CTSCOTT I got the driver side lifted ok,but iam having trouble with the other side.the axle wont go down far enough to mount the strut because its hitting the a arm.Did you have that problem? do i have to compress the strut or something
zakerya1 is offline   Reply With Quote
Tags
height tires
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
