Old 03-02-2011, 05:49 AM   #1
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
*post 115*
So just... find the brown wire, cut it, splice the side going OUT from the plug unto the white wire and leave the brown wire going INTO the plug capped?
Midnight Drifter is offline   Reply With Quote
Old 03-02-2011, 06:43 AM   #2
Correct.
Old 02-04-2014, 12:28 AM   #3
xiaoya
Drives: 2008 Yaris
I tried the mod today but with no luck. The warning light is still on after I connected brown to white. Please see the attached pic. My yaris is a 2008 one.
Thank you.
xiaoya is offline   Reply With Quote
Old 02-04-2014, 06:13 AM   #4
Thank you.
That is because you did not follow the instructions. You connected the wrong side of the brown wire to the white wire. You need to cap off the end that comes out of the connector and instead tap the end that heads up to the cluster to the white.
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
