Old 03-02-2011, 09:23 PM   #1
SailDesign
Drives: .
I had heard that the trigger pressure was around 17 psi - basically the point at which it's not just a question of wear, but of safety. TPMS does NOT mean you shouldn't check 'em by eye just as often to keep them sweet.
Old 03-02-2011, 10:14 PM   #2
It's somewhere around there for the low threshold and around 70 for the high threshold. Also, it triggers if any tire deflates more than about 6psi in 30 seconds.
Old 03-03-2011, 07:28 AM   #3
SailDesign
Drives: .
That is good to know. So it basically means "if you see the light, pull over and check NOW!"
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
Check your air pressure! YarisOwnersDad Fuel Economy Forum 23 10-26-2009 09:30 AM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
