Old 03-02-2011, 10:14 PM   #1
I had heard that the trigger pressure was around 17 psi - basically the point at which it's not just a question of wear, but of safety. TPMS does NOT mean you shouldn't check 'em by eye just as often to keep them sweet.
It's somewhere around there for the low threshold and around 70 for the high threshold. Also, it triggers if any tire deflates more than about 6psi in 30 seconds.
Old 03-03-2011, 07:28 AM   #2
SailDesign
Drives: .
That is good to know. So it basically means "if you see the light, pull over and check NOW!"
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
Check your air pressure! YarisOwnersDad Fuel Economy Forum 23 10-26-2009 09:30 AM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
