Old 03-07-2011, 04:05 PM   #1
detroiter
detroiter's Avatar
I disagree with the air filter one. Driving with a clogged air filter doesn't change fuel economy because of the OBD? That's like saying I can run a marthon in my shoes without soles just because I have laces still.
Old 03-07-2011, 05:06 PM   #2
MadMax
MadMax's Avatar
Originally Posted by markweatherill View Post
I disagree with no.3, 'increasing tyre pressure'.
Because an increase in pressures can give a noticeable boost in mpg and while it does make a car handle differently it isn't lack of grip that does that.
Errrr, yes it does! By significantly increased the tire pressure, you are changing the contact patch of the tire. That leads to decreased rolling resistance but also sacrifices traction. If done smartly it can be manageable; but like everything else in life it's a trade-off.
Errrrrr....again, the car "adjusts" to the decreased airflow, but even with a very dirty filter it is minimal at best and still doesn't restrict airflow as much as it does allow crap going down the intake that you don't want there!
Honestly, do you notice some increase in gas mileage when you put in a new air filter? I never have, with this car or any other. It just makes good sense to replace it to keep the crap that it filters from getting into the engine.
The air conditioning one makes sense as well, the aerodynamics are greatly affected at speed with the windows down. At slower speeds it's not as bad, but on the highway at constant speeds it makes more sense to roll up the windows and use the a/c. In town with stop-and-go traffic, it will significantly decrease your gas mileage; but that's usually when most people want/need it!
Cheers! M2
Old 03-07-2011, 05:29 PM   #3
I'm just going to say a few things.
I have a SGII, and when I turn on the AC on the freeway, I take a 10 mpg hit. If I open either front windows or both, I do not see any mpg differences, so for the Yaris, AC does matter.
As for the tire pressure, I'll let you guys read this: http://www.officer.com/article/artic...on=19&id=27281
Clogged air filter? Since it'll reduce performance, people are going to mash on their gas more, so it'll cause a decrease in mpg, even if the ECU tries to compensate for a dirty filter.
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 04:14 PM
Something aint right with the gas jambo101 Fuel Economy Forum 11 12-26-2008 11:13 AM
can't fuel gas onizuka Canada 20 10-28-2008 09:32 PM
My Work, Your Work - Stories and Fun SmallCarGuy Off-topic / Other Cars / Everything else Discussions 0 09-02-2007 07:43 PM
