Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-09-2011, 02:51 AM   #1
syntax
syntax's Avatar
@ rye kapag pinaiinit ba ang springs ano ang nangyayari? bumababa ba? i mean spring steel un diba? kapag lumamig babalik din diba sa original nya?
Old 03-09-2011, 03:09 AM   #2
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
syntax, s pagkakaalam ko, and dapat pagbasihan sa coil spring ay ang tensile strength nito. bawat uri ng steel may process na dinadaanan, d ko lng sure kng dumaan b both hot & cold process ang mga lowering spring.
kapag pinainit kc natin ang spring to a certian degree, may possibility na ito mag deformed and can affect both tensile and compression strength. already processed na kc ito based sa design na naka alot d2, kapag pinadaan pa ulit ntin sa isang process, mawawala na ang tibay nito. (this is just my 1 cent knowledge 'bout steel process).
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 03-09-2011, 03:25 AM   #3
xtremist
xtremist's Avatar
balik ako sa tanong mo kung ano manyayari kapag pinainitan, depende pre sa temperature na iaaply mo, may certain temp. capacity kc ung steel spring. but most probably, sa basic steel process, lalambot ito at magiging elastic, bumabalik din ito kapag lumamig but don't expect sa original state.
Ciao !!!
Looking to buy a 2006 Yaris - opinions hellboy99 New YARIS Purchase Forum 1 06-04-2010 08:45 PM
Why you should buy a Yaris. justoneyaris New YARIS Purchase Forum 9 11-02-2008 02:05 PM
