Old 03-09-2011, 07:46 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
switch the wire...has to be the reverse grounding system..
Old 03-09-2011, 07:50 AM   #2
david_mackk
Drives: Yaris 5dr LB
Which wire? Sorry first time installing them. What's the reverse grounding system?
david_mackk is offline   Reply With Quote
Old 03-09-2011, 09:38 AM   #3
marcus
toyota
marcus's Avatar
switch the wire going to the battery if you got red for positive put that wire on negative terminal and black ofcourse on positive terminal ..that should work..if your not using relay.. switch the socket from the ballast and just turn it around
Old 03-09-2011, 09:51 AM   #4
Vinceb
Drives: 2008 5 Speed Sedan
Toyota headlamps use a ground switching system, this means that there is a common positive and when you switch from high to low the relay switches which side is grounded.
Other vehicles have a common ground and switch the positive side.
Vinceb is offline   Reply With Quote
$120 AUS PER KIT XENON XTREME SLIM HID $120 JDMWAT Items for Sale by private party 0 03-02-2011 02:27 AM
Electric Windows Stopped Working !?!? MattyP DIY / Maintenance / Service 0 09-14-2010 07:20 AM
Valet 712t not working yaris prime In Car Entertainment + Electronics (audio / video / alarm) 2 04-23-2009 06:53 PM
System not working! Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 20 06-02-2007 08:54 PM
Working at Volkswagen elsteverino889 Off-topic / Other Cars / Everything else Discussions 22 05-07-2007 07:29 PM
