Old 03-10-2011, 11:50 AM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I'm at 192,000 and no water pump issues ... most likely something at the factory when they installed it I would think?
devinlamothe is offline   Reply With Quote
Old 03-10-2011, 03:00 PM   #2
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
No, they just go out sometimes. In fact, when I had a Honda they recommend replacing the water pump the same time you replace your timing belt.
My last car (a GM model) had the water pump go out when it had just 8000 miles on it.
DebbyM46227 is offline   Reply With Quote
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
Water Pump being replaced... Rental Car! slothman86 DIY / Maintenance / Service 12 08-11-2010 04:14 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
