Old 03-11-2011, 08:15 AM   #5
Vinceb
Drives: 2008 5 Speed Sedan
Agree with "Yaris2010RS. Check the tension of the serpentine belt, is there a tensioner pulley on the yaris or is tension kept on the belt from the tightness of the alternator? I haven't done enough work on it as of yet and don't have any manuals for it. anyway, if it has a tensioner pulley, that could be the problem. depending on how bold you are, back off the tension on the belt, remove it, and spin each pulley freely to see if they squeal. if not that, crawl under the car and look for loose plastic splash shields, or the metal exhaust shield. Other than that, not sure what it could be without seeing it.
Since the Yaris has a timing chain, I don't think you'll mess up the timing by removing the belt, but look for TDC (top dead center) marks on the pulleys, if they are there, you will have to re-align before putting the belt back on. this could be alot of work for the cramped engine compartments of the Yaris.
Vinceb is offline   Reply With Quote
Metal on metal rotating wheel noise phyrefighterjay General Yaris / Vitz Discussion 7 04-19-2010 11:31 AM
Clicking noise when jerking steering wheel side to side/hit bumps left side eii DIY / Maintenance / Service 8 03-22-2010 06:46 PM
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 10:09 AM
Loud scratching noise dngz General Yaris / Vitz Discussion 3 09-11-2006 10:56 PM
