#1 | |
This might explain my starting issue. I'll pull my harness this weekend and take some pics.
#3 | |
sorry to run this on two forums, but it helps everyone I think:
Boomslang: Quote:
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
If I remember correctly, I tapped the MAGI+ and MAGI- wires to crank + and crank ground respectively, and the MAGO wires (+ and -) were left unused.
EDIT: What Garm quoted makes perfect sense as well. Basically just try all three methods until you get one to work. I don't understand why intercepts didn't work for me but whatever - taps work. Oh yeah and Adrian - I hate to say I told you so but... Well, I did.
How does the FIC retard timing if the crank signal isn't intercepted? Does it also intercept the 4 ignition signals?
It only connects to the injectors, CAM, Crank, and MAF. There is no direct control over spark, just timing via intercept of the crank (if it is wired in intercept mode).
That's what I thought. That's why I don't understand people's problems with it wired in series with the FIC.
I finally had a chance to double check my wiring today. It turns out I intercepted the positive crank wire, and tapped the negative. Same with the cams. I also verified ignition can, in fact, be adjusted.
Mr. 155 and climbing
2007 Yaris Sedan
Custom T28 Turbo 7psi underdrive crank pulley 15" stock steelies winterforce tires AEM F/IC AEM UEGO Wideband High Flow Cat 2.5" mandrel bent exhaust MagnaFlow 6" canister universal high flow muffler 91 octane with STP octane boost HKS Super Sequential BOV ![]() No video at this time. Will record video after fuel pump is upgraded possibly within next 30-60 days.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. Last edited by fnkngrv; 02-25-2012 at 03:37 PM. |
excellent!
What changed from all the "going lean at 5k" etc.?
Well that is an interesting story. Apparently they had heat soaked the motor to the point that while on the dyno during his first pulls the car was going rish and then super lean at around 52-5400. During the 3 days he had my car he did 28 dyno pulls. On the evening before I came back to the shop he took the car out and did a road test. When he did that he was noticing that he was able to get to around 6100 before it would do the same thing. Alex wasn't surprised because of course a dyno is not the road. He made some final adjustments and didn't soak the motor as deeply and then took it out for another test drive immediately. He was still being able to run up to 6k. He also feels that I am actually around 180-185HP on the road. I picked up the car late yesterday afternoon and drove it the 420 miles home. The car ran great for the most part. I know that I have some work still left to be done to have it as close to perfect that an F/IC can get it. My plans are still to go with a stand alone down the road. The F/IC is merely a stepping stone. He said that he could not confirm for sure that once I upgrade my fuel system whether or not it will net more power, but he feels that it could because the car is still producing power when he lets off at the 5900/6000rpm point.
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Nice! Glad it looks like you finally got the kinks worked out of it man. Have you done the new paintjob and all that jazz yet?
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#14 |
^ not yet. slated for End of March into April if all goes well.
#15 |
Awesome, I'm looking forward to seeing that one when it's finished up.
BTW I bought a machine gun instead of a subwoofer, lol.
#16 |
Only Happy When it Rains
ok that is just awesome.
Colin Chapman disciple |
#17 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Fucking awesome. Damnit...i really want to build my turbo kit for the Yaris. But i have to finish the race car first.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#18 |
At this point I would go with Garm's Zage instead of building a custom one. The reasons are mainly 2 fold. One is that with Garm you will have vendor support, not to say that Carlos doesn't support me because he does, but he isn't making anymore kits either. I am referencing Zage/Custom. The other part of this is community support. The second is that even though having the MAF sensor where mine is near the TB and it providing more accurate temps it does cause some tuning issues as opposed to the location with the Zage. Now this would be a moot point if I was running a full stand alone, but if you are looking for an actual "kit" then the Zage works well as it is when coupled to an AEM F/IC per the community.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| HKS turbo for mk1 yaris 1 litre 1SZ-FE | nuttallacpw | Items for Sale by private party | 10 | 01-26-2011 05:03 PM |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
