Old 03-14-2011, 05:44 PM   #1
big lo
big lo's Avatar
Drives: 2007 VIOS
The water pump is easy, but that's for another thread lol, good luck buddy
TRD sportivo springs,Tokico Blue Shock/Struts,TRD rear sway bar & front bar,Tanabe engine bar,MI hoses (red), MI engine cover,SRI intake,VIOS vent visors,VIOS foglights,VIOS tails (HELLA lights & the Series 5 too),VIOS radio,VIOS badge,VIOS grill,18 inch R-1 rims wrapped in nankang tires 215/35-18z,chrome handles,retrofited the headlights, SHARK body kit (VIOS), Coming soon projectors heads with LED strip, Custom seats, MI hood lifts,MI momo steering wheel, sound system :)
Old 03-14-2011, 08:35 PM   #2
auxmike
auxmike's Avatar
It's not THAT easy. It IS a big job that may not be something everyone will want to try on their own.
Getting the bottom alt. bolt off can be enough of a discouraging experience to turn away many....
Getting the water pump off the block requires either lowering the engine by unbolting the mount or pushing the engine with a big prybar that can dent up the A/C lines in the process.
I've done the procedure, it's not fun...
Old 03-14-2011, 10:51 PM   #3
GeneralDon7
Drives: Yaris Sedan
Id have to agree, I have tried for the past three weekends to get that bottom bolt loose, and I dont know how tight they make it at the factory, but I tried everything from a two foot pipe for leverage to liquid wrench. I finally had to cave and get it done at a mechanics shop before it broke on my fiancee since we share the car. If anyone has any other tips, I am open to anything, since I hate taking my car to a mechanic for general maintenaince.
GeneralDon7 is offline   Reply With Quote
Old 03-15-2011, 07:45 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
It might not be easy for you but in my case it was I've been working with cars since I was 13 year old I'm 35 so that's why I say its easy. I've worked with a few yaris from changing belts, water pumps, brake pads, adjusting the emergency brake and the list goes on, you just gotta know tricks is all. If you can't do the job take it to a mechanic. Now here's a tip if the bottom bolt gives you trouble use a pipe for leverage meaning if you are using a rachet insert the pipe by the hand grip this will help free the bolt, also if that doesn't work with a rubber malet you can tap the top of the alternator and she will move.
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
Pinging belt when wet or cold steveh74 Europe (continental) 0 08-22-2009 05:50 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
