![]() Drives: Yaris 2008 Hatchback 5 doors Join Date: Mar 2011
you mean the main body ecu? where can i get one of those big fuses? are they easy to find? thank you bro for the help
Correct. I am not sure about down your way, but up here, auto parts stores carry those larger fuses.
These are the fuses that are not working: 1,2,3,4,5,6,7,16,17,18,20,21,26,30,31! I'm gong to try to get the 30A DEF i dont know how to test it so i'm just going to get one of them! Do you think that if i change that one will solve my problem? Thank you!
That 30A fuse doesn't drive the feed to all of those, so I don't think that that fuse is the issue. In the picture I posted above look at the connector above the center relay labeled 4G. See if that connector is actually plugged in. It is a white connector with one very large diameter wire.
Yes that is conected right! So and my car is working properly the only thing thati thinkis not working is the locking doors and unlocking with the wireless control!
OK. How are you testing for power at the fuses?
| Tags |
| door, ecu, ecu wiring, stereo, wiring |
| Car doors are not self-locking when left unlocked | fainty_girl | General Yaris / Vitz Discussion | 27 | 03-14-2011 09:12 AM |
| lambo doors.. @@ ?? why not !!! | S69 | Cosmetic Modifications (Exterior/Interior) | 11 | 04-11-2007 05:14 PM |
| Speaker grills / holes on the doors. | IsLNdbOi | Wash, Wax, Detailing, Exterior Repairs | 3 | 09-15-2006 10:28 AM |
| do u think a coilover from tein (3 doors) will work with sedan ( 4 doors) | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-21-2006 04:59 AM |
