![]() Drives: Yaris 2008 Hatchback 5 doors Join Date: Mar 2011
I got a tester that i connect to the chassis and i see if the light turns on in the tester!
OK. Check for power on that big wire in position 4G. That should have power even with the ignition off.
I figured out that those slots that i told youwere working right just when the car was on, the cord that you toldme it's fine, so now i tested all. The fuses again with. The. Car. On and it seems that the number 26,23,17 and 16 are the ones not working, and i figured out when i saw the description on the manual that those fuses are for: 26 (id/up/MirHTR, 23 CIG (i think is for the cigarrete and actually i tried and it wasnt working i dont smoke so), 17 panel 1 and 16 panel 2!
| Tags |
| door, ecu, ecu wiring, stereo, wiring |
| Car doors are not self-locking when left unlocked | fainty_girl | General Yaris / Vitz Discussion | 27 | 03-14-2011 09:12 AM |
| lambo doors.. @@ ?? why not !!! | S69 | Cosmetic Modifications (Exterior/Interior) | 11 | 04-11-2007 05:14 PM |
| Speaker grills / holes on the doors. | IsLNdbOi | Wash, Wax, Detailing, Exterior Repairs | 3 | 09-15-2006 10:28 AM |
| do u think a coilover from tein (3 doors) will work with sedan ( 4 doors) | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-21-2006 04:59 AM |
