Excellent! So, now we know that both 1.5L and 1.3L Australian 3rd generation Yaris support cruise control.
#2 | |
![]() Drives: 2006 and 2013 Join Date: Apr 2013
I did take photos but cant resize them to upload. Many photos on this site anyway so probably not going to add a lot of value by posting mine. It was extremely easy, the airbag just popped out once the 3 pins were pushed in. I had disconnected the battery before removing the airbag and waited 10 minutes as was advised by a mechanic friend. All in all it took 20 minutes including the 10 minute battery wait and a call to the dealership to get the reprogramming code for the stereo. All plug and play, there was only one slot so couldn't get it wrong. All the functions and cruise control dash indicators work correctly. The only thing that makes it look not factory is the cover plate that is removed for the cruise control stalk can't be reinstalled as is and there is a gap around it. A photo of a genuine one with a cutout would be nice so I could cut a hole in mine and make it look neater. |
![]() Drives: Yaris 5dr 998cc Edition 2012 Join Date: Apr 2013
Hi Scott
I have a 2013 998cc UK 'Edition' (base model) Yaris and would love to fit cruise, is it possible to fit the ECM based kit to my car and if so do you supply the complete kit Scott? All the best..... Last edited by Diagnostic; 04-26-2013 at 04:07 PM. |
My understanding is that only the 1.33L 2012+ European Yaris supports cruise control. Do you know if cruise is offered as an option on any of the UK 998cc Yaris?
Unfortunately after contacting the main dealer today, they have said the 998cc is not equipped with cruise for the UK. If I were to fit an aftermarket cruise system it would affect my warranty. Well I'm not worried about that but am a little cost conscious, a Google search last night revealed the price is likely to be circa £500 ($750)
#6 | |
#7 | |
Now I'm really confused or dense; I've been assured the Rostra 250-1836 cruise stalk and the 250-4206 clutch switch will work with my car. I don't see how as its only the switches and a few wires, if the car is not pre-wired and configured theirs nothing smart for the cruise stalk to talk to. Is that right? Or am I both confused and dense? Perhaps this seller wants me to add gullible? Information provided by: Kartronix- eBay item: 261180202724 |
![]() Drives: 2009 Yaris Hatchback Join Date: Jul 2013
HI! I just got a used 2009 Yaris Manual Tranny Hatchback, California car. I have seen some threads about Cal cars no being prepped for the CC. They seem to say that those 2009 and newer are. Can anyone confirm this?
Thanks! JP |
Drives: 2012 toyota yaris le Join Date: Oct 2013
hi scott,
i just bought a 2012 yaris and would like to install cruise control on it. i live in arizona. can i buy the parts from you? |
Yes. PM sent.
![]() Drives: 2011 Yaris Hatchback Join Date: Jan 2014
You are my hero. It was the clutch switch hookup. It is pretty difficult to work under the dash, and I suppose I didn't make one of the clutch switch connections correctly. This time, I took the seat out so it was easier to work and made the two connections work. I screwed up one to my splicers and soldered the connection instead. Soldering is actually easier than using the splicers, and it is obvious when it is done right. When I installed the CC in my Yaris, it would work without the clutch switch hooked up. In fact, I saw how the brake switch worked and figured out a way to install a micro switch I had left over from my days as an airplane mechanic instead of buying a Rostra switch.
What other products do you sell besides the CC? |
![]() Drives: 2010 2-Door Hatch Join Date: Jan 2014
Hey I have a base model 2010 Yaris Liftback with A/T. From what I'm gathering from the PDF all I need is the stalk and (if I want) the new boss cover. I won't need to run any wires to the ECU. Is this correct?
Thanks! |
That is correct.
#14 |
#15 |
![]() Drives: 2012 Yaris 4d Auto Coupe Join Date: Aug 2014
OEM Cruise Control
Mr. Scott,
You are a man of your word and then some! ![]() By far the best simplest installation ever! I got home late from work, looked over the instructions and thought maybe I should wait when I had more time, it's already dark... I sat down and really read the instructions and realized I was done after step 2! So went out and did it. The thing that took the longest was finding a T30 to fit. I had a socket set of them but it was to big/short to get all the way in. But once I got one that worked I was off and running! Great job! Thank you ! ![]() ![]() Glenn |
#16 |
Drives: 2007 3 Dr A/T Join Date: Aug 2014
A++ product and install manual. Fast shipper of his kit too! Thanks Scott!
#17 |
![]() Drives: yaris 2008 sedan Join Date: Apr 2014
Guys
Does it works for 2008 toyota yaris sedan GCC specification? Thanks you |
#18 |
For a 1.3L you are limited to an aftermarket solution.
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
