Old 06-22-2016, 02:10 PM   #1
jra
Drives: 2015 yaris L
Would a 2015 five door L automatic U.S. Yaris only need the stalk and wiring to plug in to clock spring and horn? If so do you have parts for this?
jra is offline   Reply With Quote
Old 06-22-2016, 03:22 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The Series 3 cruise control installaion is very easy. See http://www.yarisworld.com/forums/showthread.php?t=37205 for details.
Old 07-01-2016, 08:08 PM   #3
jra
cruise for 2015 U.S. Yaris L, french built
Scott
Thanks for the parts you sent, took about 15 min. to install, works like it was factory installed.
Old 07-24-2016, 07:09 PM   #4
Tomsyaris
Drives: 2010 yaris sedan
Hi Scott I Sent a pm . Thanks
Tomsyaris is offline   Reply With Quote
Old 06-22-2016, 07:41 PM   #5
Sudspt
Drives: Yaris
I have a question about my Yaris. I bought it in Las Vegas and I want to make sure that the ECU will tolerate the cruise control. It's a 2007 model. It says that it was manufactured in Japan, but it's a Toyota and that's where they're all manufactured, right? Just want to clarify that this method will work before I start rounding up the parts.
Sudspt is offline   Reply With Quote
Old 06-22-2016, 07:42 PM   #6
Yes - For your car, as with all American market Yaris, cruise control will work.
Old 06-23-2016, 01:14 AM   #7
Sudspt
Drives: Yaris
Thanks! I will follow your pdf instructions and let you know how it goes! Appreciate it!
Old 07-25-2016, 07:07 PM   #8
David C
Drives: White '07 3dr LB
Hi Scott, if I was to use a switch and LED to do a basic setup, could you pinpoint the essential wires ? Would a lighted 4 way switch work as a CC stalk and on/off indicator or do the CC indicator module would still be needed to act as a smart relay ? I have a '07 3dr LB, Canada. PM me the details if possible.
Thanks
David C is offline   Reply With Quote
Old 07-28-2016, 09:40 PM   #9
bassmannate
Drives: 2008 Toyota Yaris
Just used your guide to install a stalk and wiring. Worked great! The only thing I ran into was that I read the part about the indicator as "Yes: You'll need the indicator kit" or "No: You won't need the indicator kit" so I was a little disappointed when no light came on in the cluster but so happy to have cruise control on this car! Might have to get the indicator kit sometime just to have it in there.
bassmannate is offline   Reply With Quote
Old 08-05-2016, 04:39 PM   #10
bassmannate
Well, we're on our first road trip with the cruise control and it hasn't been completely smooth. The on/off button doesn't seem to work reliably the first time after starting the car. After you get it to come on the first time, it works great.
Is this just a problem with the switch/stalk i got? Is the control just a resistor ladder and could i just install a momentary switch with a resistor across the leads?
Sent from my LG-H811 using Tapatalk
Old 08-05-2016, 10:34 PM   #11
Where did you get the stalk?
Old 08-06-2016, 07:01 AM   #12
bassmannate
Amazon. I should have contacted you first but was trying to be sure to get it in before this trip and it was prime shipping. I've already contacted the seller to see if i can get a replacement for just the stalk since i don't want to pull all the wire out.
The good news is that if the schematics I've seen are correct, the on/off button is just a short to ground with no resistor. Worst case scenario, i mount a momentary switch to the dash and connect it across the leads coming from the back if the steering wheel.
By the way, are you still selling the indicator modules?
Old 08-06-2016, 07:38 AM   #13
The on/off is just a switch to ground. I would check all of your connection points to make sure it isn't an intermittent connection. If the stalk is one of the Chinese clones, it could be a bad switch within it as well.
I do still sell the indicator modules.
Old 07-27-2018, 06:37 AM   #14
Per Olof
Drives: Toyota yaris G 2014
Smile
Hello Im new in forum,I have Yaris G mod. 2014 5dor. aut. smart entry&start system and want to have CC. Im swedish but live in Thailand.How can I tjeck if it possible to put it in my car.The car seem to have a diffrent ECU (ECM) It spli to 2 units behind the glove compartment.If you know about this,can you sell me one to me ??
Per Olof is offline   Reply With Quote
Old 08-06-2016, 08:08 AM   #15
bassmannate
Yeah, it might just be a bad switch internally. The rest of the functions work fine.
Old 08-09-2016, 01:39 PM   #16
bassmannate
Well, I got a chance to meter the switch finally. Getting 1.5-2 ohms when the on/off button is pressed. Not sure if that's so high that the ECU thinks that it's not ground. I suppose if there's any other resistance such as oxidation on one of the pins between the switch and the ECU it would bump that resistance up and it wouldn't know what to do with it.
Old 08-09-2016, 05:27 PM   #17
David C
Try to read the resistance between the main chassis ground next to the battery and the battery terminal itself, then compare it to the reading you're getting between the ground connection you're using for the stalk and the battery terminal. Subtract the main ground to terminal value to it and that's how much resistance that you should try to reduce. I would assume the ECU has a direct wiring to the battery terminal clamp, but the manufacturer would take for account the resistance in chassis ground when setting the value range for the CC inputs, since the stalk would be connected to chassis (same connection as the horn by connector D3, right ?).
I did the readings on my own setup (I used 2x 2-way rocker switch and connecting my ground to the bolt behind the kick panel under the steering wheel) and had a lot of resistance using that ground point compared to the main chassis ground, but still I have flawless operation so far (installed it and been using it daily for 5 days now).
However I would really doubt that the switch internal resistance of less than 2 ohms would throw every off. It sounds more like a bad contact inside the ON/OFF switch, otherwise you wouldn't be able to use all the other function flawlessly.
Old 08-09-2016, 08:33 PM   #18
That is fine. There is about 30 ohms of tolerance for each of the switch modes.
Was the ECM pin a genuine one that seated properly in the ECM connector?
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
