Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-27-2011, 06:32 AM   #9
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
BABALA: wag ikabit ang mga white bulb 1200w hindi sya plug n play, it needs relay po... un ung ask ko about d2 sa white bulb na ito kc nagkabit na ako nito before akala ko iba ito sa kinabit ko dati sa kia ko as I heard na plug n play nga sya pero akala lang pala ntin pero hindi,hindi,hindi...
yung foglight ko as per the electrician sub standard ang size ng cable plus kinabit daw connected pa sa remote door lock ni storm kaya ayun sya sunog ang fuse at wirings buti na lang malakas pang amoy ko bago masira at magputukan naagapan
ang solusyon, nagkabit ng relay for foglight ang headlight...
relay and fuse ng foglight....
relay ng headlight...
yung relay ng headlight madali lang ikabit, sa itsura palang ng mga socket alam mo na kung para saan
foglight relay + 2 pieces fuse na nasira -> 85 SR.
headlight relay H4 (assembled ready) -> 45sr. - 5sr. disc. = 40sr.
Labor charge -> 100sr. (nagpalit kc ng wirings kaya lumaki ang labor of love, hayyy)...
total = 225sr. butas bulsa
pero worth naman mas lumiwanag sya di nga lang katulad ng HID
tol Joni sa wakas naka score din ako nung clip mo
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
