Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-28-2011, 03:47 AM   #1
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by rye7jen View Post
@duke, question, hindi na ba sila nag-lagay ng inline fuse para sa relay? in-between ng relay at battery?
tol no need na for the fuse, as you can see ginamit natin sa installation ung unang original socket na naka install naman sa fuse at switches sa fuse box.. at dahil may relay nga di na po need magpalit ng higher fuse.. actually diko naitanong ito sa electrician paki correct na din po mga kayaris then ask ko din yung gumawa if tama nga yung pananaw ko, hehe..
Originally Posted by rickyml View Post
tanong ko lang po, bakit nagpapakahirap pa kayo sa relay na yan, meron naman pong mas mababang watts... like mine. ano po ba pinagkaiba? parehas din nman ang liwanag.
tol mas mataas ang wattage mas maliwanag lalo at mas malakas kumain ng load (kuryente) kaya advice nga po ng electrician ang relay para i-handle nya ang load... same lang po sa bombilya natin yan sa bahay 100 watts is brighter than 50 watts
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-28-2011, 03:49 AM   #2
rickyml
rickyml's Avatar
Drives: Yaris 2008
so, ok lng po ba yung sa akin na 380watts? kasi so far wala naman akong naaamoy na sunog... or anything unusual sa makita, fuse and wiring...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 03-28-2011, 04:01 AM   #3
duke_afterdeath
tol advice ng kabayan electrician yung design po ng wirings ng headlight at foglight ng yaris natin ay di angkop sa mas mataas ng wattage (OEM lang daw talaga ang pwede, unless gamitan nga ng relay or ballast for HID naman) marami na din daw sya ginawa na nasunog ang fuse wires at hindi lang ito sa toyota or yaris may mga ginawa na din syang ibang kotse na same problem,,, gaya nga ng nabanggit ni kapatid na rosco sa safe side na tayo... pero cyempre nasayo ang desisyon tol sakin lang po base sa experience ko mas lalaki ang problema at lalaki pa ang gastos
Old 03-28-2011, 04:12 AM   #4
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
mabuhay
well said. mabuhay si duke_smoke
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 04:23 AM   #5
duke_afterdeath
tol nawala na yung after SMOKE na lang ano kaya susunod
Old 03-28-2011, 04:30 AM   #6
EjDaPogi
EjDaPogi's Avatar
tol, kasi may RELAY na! kaya ganon! wa-pak!
Old 03-28-2011, 04:35 AM   #7
duke_afterdeath
wala bang bababa sa inyo jan d2 may ipakikidala ung pinsan ko jan papunta d2
Old 03-28-2011, 04:12 AM   #8
kiel12
kiel12's Avatar
Drives: 2011 toyota yaris Y
+1
kiel12 is offline   Reply With Quote
Old 03-28-2011, 04:15 AM   #9
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
rosco is offline   Reply With Quote
Old 03-28-2011, 03:51 AM   #10
EjDaPogi
EjDaPogi's Avatar
lufet mo talaga duke_afterSMOKE
Old 03-28-2011, 04:03 AM   #11
duke_afterdeath
busettt!!!
Old 03-28-2011, 05:26 AM   #12
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Duke, what i mean is yung relay to battery.. nag-search na kasi ako about sa relay installation at naglalagay sila ng inline fuse between the relay going directly to the battery, yan kasi yung isang rason kaya natagalan ako bago ko na-install yung nabili kong busina. Worried lang ako kung ano magiging dis-advantage nito in the long run.. Pero nung nakita ko yung relay na kinabit kay pareng brosco eh wala rin silang nilagay na inline fuse..
Eto yung gusto ko tukuyin:
Paki-correct na lang po or baka may namiss lang ako.
rye7jen is offline   Reply With Quote
Old 03-28-2011, 05:45 AM   #13
duke_afterdeath
Attachment 40739
copy tol, walang fuse in between the battery and relay sa kinabit kay storm, cguro pwede ding lagyan para mas safe...
Old 03-28-2011, 06:08 AM   #14
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Thanks tol, baka si idol jonimac ang makakapag-bigay linaw.wehehehehe!
Old 03-28-2011, 06:14 AM   #15
stinger
You got me sTiLt
stinger's Avatar
Drives: 2011 Yaris Y sedan
Attachment 40739
Pre... yung fuse is for protection base on the diagram. Mas ok kung lalagyan mo kung hindi ka gagamit ng harness na ready made.
Kung yung harness na nasa post nila gagamitin mo ok lang na wala ng fuse kasi ginamit naman na yung dating socket ng headlight which is may fuse na.
Hope this will help.
stinger is offline   Reply With Quote
Old 03-28-2011, 06:18 AM   #16
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Thanks tol stinger, mukhang hindi na nga kailangan ng inline fuse base dun sa harness ni tol ramil. Ok na rin yung malinaw para iwas confuse sa ating mga fellow kayaris.
Old 03-28-2011, 06:20 AM   #17
duke_afterdeath
+1
Old 03-28-2011, 06:22 AM   #18
EjDaPogi
EjDaPogi's Avatar
+1
fuse + fuse + fuse + too much fuse = CONFUSE!
