Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-28-2011, 03:49 AM   #1
rickyml
rickyml's Avatar
Drives: Yaris 2008
Originally Posted by duke_afterdeath View Post
tol no need na for the fuse, as you can see ginamit natin sa installation ung unang original socket na naka install naman sa fuse at switches sa fuse box.. at dahil may relay nga di na po need magpalit ng higher fuse..
tol mas mataas ang wattage mas maliwanag lalo at mas malakas kumain ng load (kuryente) kaya advice nga po ng electrician ang relay para i-handle nya ang load... same lang po sa bombilya natin yan sa bahay 100 watts is brighter than 50 watts
so, ok lng po ba yung sa akin na 380watts? kasi so far wala naman akong naaamoy na sunog... or anything unusual sa makita, fuse and wiring...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 03-28-2011, 04:01 AM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol advice ng kabayan electrician yung design po ng wirings ng headlight at foglight ng yaris natin ay di angkop sa mas mataas ng wattage (OEM lang daw talaga ang pwede, unless gamitan nga ng relay or ballast for HID naman) marami na din daw sya ginawa na nasunog ang fuse wires at hindi lang ito sa toyota or yaris may mga ginawa na din syang ibang kotse na same problem,,, gaya nga ng nabanggit ni kapatid na rosco sa safe side na tayo... pero cyempre nasayo ang desisyon tol sakin lang po base sa experience ko mas lalaki ang problema at lalaki pa ang gastos
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-28-2011, 04:12 AM   #3
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
mabuhay
well said. mabuhay si duke_smoke
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 04:23 AM   #4
duke_afterdeath
tol nawala na yung after SMOKE na lang ano kaya susunod
Old 03-28-2011, 04:30 AM   #5
EjDaPogi
EjDaPogi's Avatar
tol, kasi may RELAY na! kaya ganon! wa-pak!
Old 03-28-2011, 04:35 AM   #6
duke_afterdeath
wala bang bababa sa inyo jan d2 may ipakikidala ung pinsan ko jan papunta d2
Old 03-28-2011, 04:38 AM   #7
EjDaPogi
EjDaPogi's Avatar
i-RELAY na lang natin!!!
Old 03-28-2011, 04:39 AM   #8
kiel12
kiel12's Avatar
Drives: 2011 toyota yaris Y
duke si jherton tanungin mo kc yung isang kasama nya sa work eh weekly ang punta dyan sa riyadh..
kiel12 is offline   Reply With Quote
Old 03-28-2011, 06:08 AM   #9
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
MAGKIKITA KAMI NI aldrin ka tropa ni jherton dadalhin niya yung decals duke kung gusto mo punta ka dito la paza maya mga 130 to 2pm ...para kunbg ano maipapadala mo padala mo na..pera bayan?..
rosco is offline   Reply With Quote
Old 03-28-2011, 04:12 AM   #10
kiel12
kiel12's Avatar
+1
Old 03-28-2011, 04:15 AM   #11
rosco
rosco's Avatar
