Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-28-2011, 03:51 AM   #1
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Originally Posted by duke_afterdeath View Post
tol no need na for the fuse, as you can see ginamit natin sa installation ung unang original socket na naka install naman sa fuse at switches sa fuse box.. at dahil may relay nga di na po need magpalit ng higher fuse.. actually diko naitanong ito sa electrician paki correct na din po mga kayaris then ask ko din yung gumawa if tama nga yung pananaw ko, hehe..
tol mas mataas ang wattage mas maliwanag lalo at mas malakas kumain ng load (kuryente) kaya advice nga po ng electrician ang relay para i-handle nya ang load... same lang po sa bombilya natin yan sa bahay 100 watts is brighter than 50 watts
lufet mo talaga duke_afterSMOKE
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 04:03 AM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
busettt!!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
