Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-28-2011, 04:58 AM   #1
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by rye7jen View Post
Ricky ilang watts yung white bulb mo?
tol rye, 380watts ung nakakabit ngaun kay tol ricky....
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-28-2011, 05:29 AM   #2
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Thanks tol, chineck ko kahapon yung watts nung white bulb na binili namin ni tol brosco 550watts .... pansin ko parang nagcocorrode na yung terminal ng headlight mismo..normal ba ito? Kuhanan ko ng pic pag makalibre..
rye7jen is offline   Reply With Quote
Old 03-28-2011, 05:40 AM   #3
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
scary naman itong post mo. how much more to us na gumagamit ng 1,200W? waaa!
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 05:44 AM   #4
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Ej, no need to worry, wala naman sign na natunaw or nasunog mga wires, taka lang ako bat parang may corrosion na yung terminal connection nung headlight. Iniisip ko na lang na sana e epekto lang ng tubig or something.
Old 03-28-2011, 05:48 AM   #5
EjDaPogi
EjDaPogi's Avatar
un ba yong parang toothpaste pag hinugot mo ung socket?
Old 03-28-2011, 05:50 AM   #6
duke_afterdeath
tol normal lang yan wag lang mag aamoy sunog ant medyo nadidiform na ung terminal or socket ng headlight... pero cguro tol wag mo na hintayin un
Old 03-28-2011, 06:00 AM   #7
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
normal yan pre' nagtaka din ako dati kung bakit ganun ang itsura nun na parang luma na malangis, pero nakita ko rin un sa ibang kayaris ay ganun din pala ang itsura...
syntax is offline   Reply With Quote
Old 03-28-2011, 06:12 AM   #8
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Salamat mga bro's! Paranoid mode ako ngaun ah.hahahahahaha!!!! Toinks~
Old 03-28-2011, 06:14 AM   #9
duke_afterdeath
