Old 03-29-2011, 11:07 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
OK i tried taking the fuse on etcs 10 amps but the car wont stay on itll crank but it drops the rev to zero.. does battery have to be unplug too.
Old 03-29-2011, 11:16 AM   #2
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
It is a red 50 amp fuse labeled EPS. You do not have to disconnect the battery to pull it out.
DMZ is offline   Reply With Quote
Old 03-29-2011, 11:21 AM   #3
marcus
toyota
marcus's Avatar
oh maybe i took out the wrong one thought its the etcs.. now i need to find eps..thanks
what does s-lock stands for its missing a fuse in it..
Old 03-29-2011, 11:27 AM   #4
DMZ
DMZ's Avatar
Look in the fuse box on the drivers side. The EPS fuse is between the ABS and HTR fuses. It is a big, square fuse.
I am not sure what the s-lock is for.
Old 03-29-2011, 11:29 AM   #5
ETCS is one of the ECM's fuses. S-LOCK is for the AT shift lock. If you have a MT it will be empty.
Electric power steering Geoff Peace DIY / Maintenance / Service 4 04-10-2018 05:28 AM
Power Steering Fluid jstantherprsn DIY / Maintenance / Service 8 04-05-2016 06:24 PM
Power Steering Light sıɹɐʎ DIY / Maintenance / Service 12 02-19-2014 07:22 PM
URGENT Advice Needed! Relating to Power Steering, Alternator and Electrical. The Marshall General Yaris / Vitz Discussion 25 10-21-2010 08:23 PM
Can't find power steering reservoir on '10, is there one? JerseyJeff84 DIY / Maintenance / Service 4 09-07-2010 10:47 AM
