Old 02-21-2007, 09:55 AM   #1
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
AHHH you have the badges done EXACTLY how I'm going to do mine. What was your process? I also LOVE those seats! What brackets did you use to mount them?
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline   Reply With Quote
Old 02-21-2007, 10:20 AM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Looks great...... Man i MISS that place!!!!
Old 02-21-2007, 11:55 PM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
thanks man , the badges i use a good plastic primer first then a engine enamel that is heat resistant to spray them , took about 1 hour to do.the front badge just clips out no prob , the back one is on with some serious glue , i just used some fishing line and worked it loose.just be carefull as there is 2 small plastic pins attached to the badge which alignes it into the body , take care when pulling the back one off.and to put the back one on again , just used some waterproof double sided tape and cut it to the exact thinkness of the badge and stuck it back , works like a charm.
as for the seats my buddy and i designed and he fabricated brackets that utilise the existing seat rails that bolt off the old seats so we didnt damage the old rails we made a bolt on system , so if u want to put the old seats back you can.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
stock ride height or spring sag? mikeukrainetz General Yaris / Vitz Discussion 5 12-21-2006 01:00 PM
Waiting on my ride wibrian Great Lakes 23 11-19-2006 08:05 AM
Air Ride suspension for Yaris Sedan fouad84 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-13-2006 07:39 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
NSR's ride tca4 Photo-Video-Media Gallery 18 07-24-2006 04:26 AM
