![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
yea its not really a constant tinging, more like a "ting ting".....and its very noticable inside the car even with the radio on and even worse outside. Its actually embarrasing having that noise come from a car thats 5 months old.........
im wondering if the nst pulley would be different........ but i actually think there may be a design flaw in the pulley somewhere....
Mine is NST.
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
hey don't know if someone may have asked this already but how do you keep the stock pulley from turning when you are loosening the bolt.
k... i mean i guess i understand that part, and i can use one of those from work but i just assumed the pulley would still turn to the left whether using a ratchet or impact unless you hold it in place with something.
Not really....with enough force the impact hits it so hard it will spin it right off. I hit mine and it started to turn so I stopped and hit it again...it's technique and if you use them at work shouldn't be a problem. Just get it loose and use fingers to take off. Don't lose track of the little pin and be sure to re-install it.
lol... well i don't actually use them. those just aren't really in my job description. nevertheless i will give it a shot. wasn't sure but now i know.
thank you much. |
Getting it off is cake... The real difficult part is torqueing down the bolt to 128ft/lbs when putting the new pully on.
That is the torque amount called for....and what I would recommend. Now how to get it there with a big old torque wrench in the small confines is the problem. Ahem....tell you what I did....after replacing with the NST pulley, and replacing the little dowel pin and with the threads on the crank and nut all clean checked by securing on the crank by hand several times....I placed a couple of drops of loctite close to the nuts final resting point and by hand ran it all the way and then hit it hard with the air impact wrench. Just remember to take your time, try it a few times for feel, make sure it goes back the way it came off (just replacing a wheel, nothing else), drop or 2 of Loctite and don't crossthread (why I ran it all the way by hand before impact wrench).
Disclaimer: Torque to limit as specified. |
#11 | |
Many on this forum will be appalled by using a torque wrench to tighten anything, but as always, if you know a better way please share. |
hmmm... well today i was off work but really wanted to give this a go so i went to a hardware store and bought an electrical impact wrench just to see. work for me is 90 miles away and i don't usually make a habit of taking my car out that way because i can just ride with the welder i work with anyway. i figured buying a power impact wrench to save me from putting 180 miles on my car was a fair trade. i thought hell i might even get some other uses out of it anyway.
well of course it didn't go as planned... had the car jacked up, wheel off, alternator loosened from the bracket and everything (AGAIN) but the thing just wouldn't budge. so that kinda sucks. guess i will just break down and drive to work tomorrow to use the air impact. a half want to just say screw it and pay someone else to do it cause i'm kinda getting tired of mucking with it at this point. i just had no idea that thing would be on there that dang tight. |
Many on this forum will be appalled by using a torque wrench to tighten anything, but as always, if you know a better way please share.[/QUOTE]
No I don't at least in regards to the crank pulley and yea I would and did check my air wrench output when I did mine. You put it better though in regards to the topic. I hope they get it right either way. |
I'm going to be installing the crank pulley soon myself, and was wondering....
Couldn't you just put the car in gear (manual trans), and have a friend step on the brakes while you loosen or torque down the crank bolt? The clutch would hold under 128 ft.lbs. right? IMO I wouldn't do this mod without a torque wrench...too loose and you could really F-up the crank itself when/if the bolt backs out...plus a loss of the crank pulley will kill the power to the car once the battery dies, leaving you stranded. |
#15 | |
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
Sorry to bump an old thread. I know there was a time when the crank pulley served as part of the crank balance on engines. Is there a risk with this Lite pulley throwing off the reciprocating mass and shortening engine life? Why wouldn't Toyota have just made a pulley like this OEM?
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
Yes ^ don't do it.
#18 | |
![]() ![]() Drives: Red 2007 Yaris Sedan Join Date: Apr 2007
