Old 02-21-2007, 03:46 PM   #1
barryware
I used a Fumoto on my kids crotch rocket. It has been there for a couple of seasons and it shows no signs of leaks or anything.
He uses synthetic oil and it drains out pretty fast but we make sure the engine is hot before changing the oil.
I wanted to use it because the oil drain is directly in front of the rear tire. If you don't tighten it enough, you run the risk of it vibrating loose and possibly coming out. Not good to have oil dumping in front of your rear wheel on a bike. If you over tighten the drain plug, you can damage the oil pan. The stock drain plug is made of steel and the oil pan including threads are made of aluminum.
I installed it to lesson the risk of damaging the oil pan but it does make it a lot easier to change the oil. The easier part is a bonus.
Because I change my own oil, I may put one on the Yaris.. Till reading this thread, I never thought about it much.
barryware is offline   Reply With Quote
A related thread to "What's Next for the Yaris" (Ethanol) Goose General Yaris / Vitz Discussion 15 06-05-2007 04:15 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
oil changes on your Yaris asa805 DIY / Maintenance / Service 34 07-26-2006 11:41 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
