Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 04-04-2011, 01:46 AM   #1
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Originally Posted by jonimac View Post
Factor yung wattage tol. 1.2k watts ba yan?
Originally Posted by xtremist View Post
pre, how about HID, ganun din ba kainit?
@joni, just a thought. knowing that the relay is just 100W, do you think the Xenon is burning 100W power only?
@jeff, haven't seen HID up close & personal. hayaan mo at papara ako ng isang arabo para sau.
EjDaPogi is offline   Reply With Quote
Old 04-04-2011, 01:48 AM   #2
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
ok na pala eh, dyan nalang tayo mag ihaw sa headlight mo
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 04-04-2011, 01:50 AM   #3
kiel12
kiel12's Avatar
Drives: 2011 toyota yaris Y
mga sadik ako naka HID hindi naman sya mainit pag hinahawakan ko parang stock lang sya..
kiel12 is offline   Reply With Quote
Old 04-04-2011, 01:53 AM   #4
EjDaPogi
EjDaPogi's Avatar
confused. in the state of dilemma.
HID & Projector Lamp --- are they the same? or the projector lamp ay ung casing?
Old 04-04-2011, 02:02 AM   #5
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
HID - uses ballast, special bulb
Projector lamp - uses stock bulb, lens projection type.
That's what I know.
jonimac is offline   Reply With Quote
Old 04-04-2011, 02:06 AM   #6
EjDaPogi
EjDaPogi's Avatar
That's what I know.
@joni, ito na pong kasagotan:
http://en.wikipedia.org/wiki/Headlamp
Old 04-04-2011, 02:09 AM   #7
xtremist
xtremist's Avatar
wala ka sa hulog, ikaw may tanong, ikaw din may sagot...wahahahaha
Ciao !!!
Old 04-04-2011, 02:11 AM   #8
jonimac
jonimac's Avatar
Bwisett! sige basahin mo!
Old 04-04-2011, 02:14 AM   #9
EjDaPogi
EjDaPogi's Avatar
@joni/jeff, sinipag akong mag-google eh! ngakngakngak!
HID (xenon) light sources
HID stands for high-intensity discharge, a term referring to the electric arc that produces the light. The high intensity of the arc comes from metallic salts that are vapourised within the arc chamber. These lamps are formally known as gas-discharge burners, and produce more light for a given level of power consumption than ordinary tungsten and tungsten-halogen bulbs. Because of the increased amounts of light available from HID burners relative to halogen bulbs, HID headlamps producing a given beam pattern can be made smaller than halogen headlamps producing a comparable beam pattern. Alternatively, the larger size can be retained, in which case the xenon headlamp can produce a more robust beam pattern.
Automotive HID lamps are commonly called "xenon headlamps", though they are actually metal halide lamps that contain xenon gas. The xenon gas allows the lamps to produce minimally adequate light immediately upon powerup, and accelerates the lamps' run-up time. If argon were used instead, as is commonly done in street lights and other stationary metal halide lamp applications, it would take several minutes for the lamps to reach their full output. The light from HID headlamps exhibits a distinct bluish tint when compared with tungsten-filament headlamps.
[edit] Projector (polyellipsoidal) lamps
In this system a filament is located at one focus of an ellipsoidal reflector and has a condenser lens at the front of the lamp. A shade is located at the image plane, between the reflector and lens, and the projection of the top edge of this shade provides the low-beam cutoff. The shape of the shade edge, and its exact position in the optical system, determines the shape and sharpness of the cutoff.[17] The shade may have a solenoid actuated pivot to provide both low and high beam – the shade is removed from the light path to create high beam, and placed in the light path to create low beam, and such optics are known as BiXenon or BiHalogen projectors, depending on the light source used. If there is no such arrangement, the cutoff shade is fixed in the light path, in which case separate high-beam lamps are required. The condenser lens may have slight fresnel rings or other surface treatments to reduce cutoff sharpness. Recent condenser lenses incorporate optical features specifically designed to direct some light upward towards the locations of retroreflective overhead road signs.
Hella introduced ellipsoidal optics for acetylene headlamps in 1911, but following the electrification of vehicle lighting, this optical technique wasn't used for many decades. The first modern polyellipsoidal (projector) automotive lamp was the Super-Lite, an auxiliary headlamp produced in a joint venture between Chrysler Corporation and Sylvania and optionally installed in 1969 and 1970 full-size Dodge automobiles. It used an 85 watt transverse-filament tungsten-halogen bulb and was intended as a mid-beam, to extend the reach of the low beams during turnpike travel when low beams alone were inadequate but high beams would produce excessive glare.[24]
Projector main headlamps first appeared in 1981 on the Audi Quartz, the Quattro-based concept car designed by Pininfarina for Geneva Auto Salon.[citation needed] Developed more or less simultaneously in Germany by Hella and Bosch and in France by Cibié, the projector low beam permitted accurate beam focus and a much smaller-diameter optical package, though a much deeper one, for any given beam output. The version of the 1986 BMW 7 Series sold outside North America was the first volume-production auto to use polyellipsoidal low beam headlamps.
DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation CTScott DIY / Maintenance / Service 172 10-27-2025 02:04 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 03:42 PM
Request for help: diagramming a relay BailOut In Car Entertainment + Electronics (audio / video / alarm) 25 07-12-2009 12:59 PM
