Old 04-05-2011, 05:00 PM   #1
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
Ouch $2000. Guess I'll be content with turning the knob.
Freedan is offline   Reply With Quote
Old 04-05-2011, 08:36 PM   #2
If you can source the parts used from Europe or Japan it can be done considerably cheaper (~$500). Echo_hrs purchased two sets of parts from the Yahoo Japan auctions, and sold me one of them. I figured out how to make it work on a USDM Yaris, and actually still owe him a plug and play harness to get his working.
Old 04-06-2011, 05:54 AM   #3
Per Kristian
Drives: Yaris D4D
Thanks for your help Scott!
Did you find out if all the parts on this list is nessesary? I live in Europe, and have a donor car to pick the parts from
Did you fit this in your car. Do you have picture of the fitting :-)
55900-0D210-B0 Control Assy, Air Conditioner
(This is the entire center dash assembly including the "knobs", electronics, and trim)
87106-0D020 Servo Sub Assy, Damper (For Airmix)
87106-0D040 Servo Sub Assy, Damper
87106-0D030 Servo Sub Assy, Damper (For Mode)
(These three replace the manual dampers with ones which are controlled by the above part)
82212-52020 Harness Assy, Air Conditioning, LHD
(I believe that this is the entire cable assembly, including connections to the above and below parts)
88625-47031 Thermistor Cooler (Solar Sensor)
(Sensor mounted under upper dash)
88625-22131 Thermistor Assy
(Sensor mounted in front bumper)
88625-47021 Thermistor, Cooler
(Sensor mounted behind AC controls)
88650-0D160
(This is the AC control module, which is mounted to the bottom of the AC assembly)
Per Kristian is offline   Reply With Quote
FS Part 1: Many Stock Yaris Parts Kenshin Items for Sale by private party 5 11-23-2009 10:17 PM
LF: Yaris / Vitz / Echo hatch accessories / parts! Keej_05RS General Yaris / Vitz Discussion 3 12-08-2008 09:43 PM
