YarisCraze
Drives: 2008 Yaris Type S Join Date: Apr 2011
The diagnostics code is P0011. I'm going to replace the Oil Control Valve (OCV) (Manufacturer Part #: 1533021011) since it's only $75 dollars and go from there. The part is available at: http://www.toyotapartszone.com/oem/t...330-21011.html
Thank you both for the good info. I'll make sure to post my results in order to save other people some time with this issue. It has really been a pain in the rear. It's 5 O'clock! Thanks Again!
#2 | |
advocatus diaboli
It's a piece of cake fix. Disconnect neg battery cable. Drop the alternator bracket and unbolt/unplug the old OCV, you'll need to give it a little twist then it will slide right out. New one goes in the same way, bolt up, re bolt alternator bracket....done. With that code I believe there was only two real options, OCV or camshaft gear...thank goodness it wasn't camshaft gear. |
#3 | |
GRO H2O
Drives: Yaris Join Date: Apr 2011
#4 | |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Question About Engine Oil | Kaotic Lazagna | Off-topic / Other Cars / Everything else Discussions | 21 | 08-29-2009 03:08 AM |
| WTB: Oil Control Valve/VVT Valve | bdc87 | Willing to Buy by private party | 4 | 05-22-2009 08:15 PM |
