Old 04-12-2011, 05:18 PM   #14
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Originally Posted by netspec239 View Post
The diagnostics code is P0011. I'm going to replace the Oil Control Valve (OCV) (Manufacturer Part #: 1533021011) since it's only $75 dollars and go from there. The part is available at: http://www.toyotapartszone.com/oem/t...330-21011.html
Thank you both for the good info. I'll make sure to post my results in order to save other people some time with this issue. It has really been a pain in the rear. It's 5 O'clock! Thanks Again!
It's a piece of cake fix. Disconnect neg battery cable. Drop the alternator bracket and unbolt/unplug the old OCV, you'll need to give it a little twist then it will slide right out. New one goes in the same way, bolt up, re bolt alternator bracket....done.
With that code I believe there was only two real options, OCV or camshaft gear...thank goodness it wasn't camshaft gear.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Question About Engine Oil Kaotic Lazagna Off-topic / Other Cars / Everything else Discussions 21 08-29-2009 03:08 AM
WTB: Oil Control Valve/VVT Valve bdc87 Willing to Buy by private party 4 05-22-2009 08:15 PM
