Old 04-13-2011, 04:56 PM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
See if your front struts have slotted holes(top bolt). If so, you can have an alignment shop adjust them to get some negative camber going. If that's not the case, you can get some camber bolts from "Garmu-San".
marlondog is offline   Reply With Quote
Old 04-14-2011, 09:58 AM   #2
3cyltrbo
The top bolt on the struts ARE slotted and they ARE pushed all the way to promote camber and try to alleviate(sp) the rubbing
3cyltrbo is offline   Reply With Quote
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
