Old 04-14-2011, 12:44 AM   #1
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
sitting that low your gonna need camber,might of gone with a 45 profile instead of 50....but some camber will take most of the rub away.
for the fronts you can put a spacer behind the fender where it meets the bumper,put it at the bottom by the wheel where the bumper and fender meet.
The xB guys been doing this for a while,the bumper will stretch about 3/4" out at the bottom and still look right,so you can push out the fender about 1/2" with spacer and remount the bumper.
That will give you some more space for the tire lean when going slow and turning.
Old 04-14-2011, 10:07 AM   #2
3cyltrbo
ARGHHHHH
WHY DIDN'T I RESEARCH THE TIRES MORE!!!!!!!!!!!!!!!!
I actually found a 195/45/16 in a Yokohama tire (I love YokoHamas!!!)
DAMN
But, its also 1.2 inches smaller outside diameter and that would have definitely thrown off the speedo.
I'm 100% gonna look at this founder mounting thing, and I'm also gonna think about modding the stock fender liner (cutting the section out that rubs / and fibreglassing in a new section that is higher)
3cyltrbo is offline   Reply With Quote
Old 04-14-2011, 10:13 AM   #3
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Just a thought....since the inner fenders are plastic, is it possible to heat them with a heat gun and shape them?
Old 04-14-2011, 03:28 PM   #4
3cyltrbo
I was thinking the exact same thing
I also thought about riveting in new pieces of plastic (reshaped)
and I was even wondering about the potential to cut out the areas that rub and fibreglass in - new parts with increased clearance.
W
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
