Old 04-14-2011, 01:37 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
My ass told me so when my boost gauge read 0 and I was only at 2000 rpm. As soon as I took the turbo off, I didn't have nearly the same pull at 2000 rpm.
The whole point of it is to make a high flat torque curve from low rpms for efficiency.
Edit: Ok, the point I'm trying to make is that an N/A engine is only sucking in as much air as it can due to volumetric efficiencies. As RPMs go up air inside the air inside the intake track speeds up compounding the effect and power is increased. With the turbo, you have a constant rate of air being pushed by the turbo eliminating the need for high RPMs to achieve the desired torque.
Holy crap, sorry for thinking outside the box.
Old 04-14-2011, 01:52 PM   #2
cdydjded
Drives: Yaris LB Turbo
The reason you ass felt more pull while you were boosted & @ 0 psi is because you went from negative to almost a positive pressure. That & the factory ECU started to dump more fuel to compensate for the added air that was coming from the turbo......
cdydjded is offline   Reply With Quote
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 04:23 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
