Old 04-14-2011, 02:08 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Ok, but when you make a post stating that it can't be done, yet it's used on internal combustion engines, what am I supposed to think.
Then you post that you don't know if an NA engine reads 0 psi g at WOT. Maybe it's best you don't post about thing you only have street smarts in. Just because YOU've never done it doesn't mean it can't be done.
Old 04-14-2011, 02:17 PM   #2
cdydjded
Drives: Yaris LB Turbo
Read my first post:
That is not possible. You cannot run less boost than the W/G allows. Unless you use a pop off valve that bleeds boost. Good luck finding one that can go that low....
I specifically said how it CAN be done. And as for not know if a N/A engine reads 0, I meant it towards our engine, the 1NZFE.
cdydjded is offline   Reply With Quote
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 04:23 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
