Old 04-14-2011, 03:42 PM   #1
The top bolt on the struts ARE slotted and they ARE pushed all the way to promote camber and try to alleviate(sp) the rubbing
I think we can assume from this that you haven't done an alignment. Definitely get some camber bolts and set it at -1 to -1.5 in front. Your handling will improve too.
Your height adjustment is still done on the springs, and you can adjust the shock body so your travel is still correct with that coilover; nice.
hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? tonyg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-19-2009 08:53 PM
