Old 04-19-2011, 07:08 AM   #1
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Originally Posted by Vinceb View Post
I lubed the part circled in your earlier photo, but still squeaked, I ended up removing the rubber boot and lubing inside of it on this pic, no more noise. thanks for the direction guys.
I used fluid film for the lube.
@Vinceb, how did you remove/reinstall the rubber boot? do you have to lift the car? regards.
EjDaPogi is offline   Reply With Quote
Old 04-19-2011, 12:04 PM   #2
Vinceb
Drives: 2008 5 Speed Sedan
sorry, shouldn't have said 'removed' I just pulled the boot back, and stuck the hose from the spray can inside the boot and sprayed it. The picture is taken from the top of the engine bay looking down. you can get to this part of the clutch system either from the top or by simply crawling under the front of the car, it's wide open (mind you I have a sedan and not a hatchback). if you wanted more space, get a set of ramps, but it's pretty much at the bottom of the engine bay.
Vinceb is offline   Reply With Quote
Old 04-20-2011, 02:21 AM   #3
EjDaPogi
EjDaPogi's Avatar
@vinceb, thank you very much!
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Way to shorten distance on clutch pedal? kac Performance Modifications 2 07-23-2009 06:42 PM
squeaky clutch TickleTimeTim DIY / Maintenance / Service 4 04-28-2009 11:36 AM
Car/engine shake when releasing the clutch pedal hystria DIY / Maintenance / Service 16 07-22-2007 07:56 PM
Hard clutch pedal ? hystria General Yaris / Vitz Discussion 5 05-11-2007 06:12 AM
