Old 04-23-2011, 02:04 AM   #1
If you think about it, at the perimeter, a larger diameter "circle" has to travel faster to achieve one revolution as a smaller circle. The outside of a larger rotor is where the pad contacts it. I'm armchair discussing here, but I do know the friction would be greater to slow the velocity, causing more heat.
And all of that might not make a huge difference. Let's hear the OP's review!
Old 04-23-2011, 08:11 AM   #2
That's true, but it's my understanding that the main advantage of larger rotors is to have more mass and surface area to dissipate heat from braking, so the temperature increase you mentioned may be canceled out.... food for thought! (and google searches )
Old 04-23-2011, 01:35 PM   #3
cfeng
Drives: Yaris 2010 Liftback
There are considerations necessary for matching a brake pad to a rotor. Usually, the inner diameter of the surface that the pad touches is 58% of the outer diameter, in order to achieve greatest braking torque.
cfeng is offline   Reply With Quote
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
big brake kit yrsdrgn Performance Modifications 17 02-20-2007 11:05 PM
cheap trd big brake kit *joke* birdy Off-topic / Other Cars / Everything else Discussions 3 06-13-2006 12:04 AM
