Old 04-24-2011, 11:08 AM   #11
cdydjded
Drives: Yaris LB Turbo
Originally Posted by Lil Abner View Post
Actually, no. You are correct about the tires rotating different per mile depending on the diameter. But that doesn't apply to the rotors. The rotors will ALWAYS rotate at the same revolutions per mile as the tires!!! This is because the rotors are attached to the wheels. The wheels to the ground.
You did not understand what I put. Obviously the tire & the rotor rotate the same revolutions. My point in using the tire calculator is cause you can use a taller tire or shorter tire which would apply to a rotor with a 12" diameter (taller) or 10" diameter (shorter). My point is no mater what it is a tire, a rotor anything with a circumference, the bigger it is the slower it rotates, the smaller it is the faster it rotates.
cdydjded is offline   Reply With Quote
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
big brake kit yrsdrgn Performance Modifications 17 02-20-2007 11:05 PM
cheap trd big brake kit *joke* birdy Off-topic / Other Cars / Everything else Discussions 3 06-13-2006 12:04 AM
