Old 04-29-2011, 11:51 AM   #1
jetaimejsc
jetaimejsc's Avatar
Drives: Yaris Hatchback
not really. At first when i moved it, the needle felt loose, but i turned car on and it felt some resistance so i moved it to 0. now i pushed it in more and it never moved up or down, just stuck on 0. So i loosened it up some but after i drive and leave the car it just falls below 0
jetaimejsc is offline   Reply With Quote
Old 04-29-2011, 11:57 AM   #2
When you adjust it powered-on, you have to pull the needle off and press it back in place. If you rotated it while powered-on, that explains why on the next trip it dropped back below zero. It only recalibrates itself on power-up. If you move the needle once it has already calibrated, you bypass the initial calibration.
Old 04-29-2011, 01:04 PM   #3
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
You always have excellent info...fun to read you excellent help info for this member.
annn is offline   Reply With Quote
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
!! Speedometer Needle Problem !!! Murtaza_murti Cosmetic Modifications (Exterior/Interior) 40 11-25-2014 10:48 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
Six speed Snyprwlf47 Performance Modifications 16 11-24-2008 09:04 PM
