Old 04-29-2011, 12:22 PM   #1
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
I found the valve A / C under pressure.
When turn on the A / C no no clicks from a relay, and there is no change in the engine. I think it may be faulty fuse or a relay.
I would appreciate it if you lay out electrical circuit on the 2007 Yaris sedan A / C.
MickZEL is offline   Reply With Quote
Old 04-29-2011, 01:06 PM   #2
To start with, check the 7.5A AC fuse in the under dash fuse panel and the 40A HTR SUB2 and 30A HTR SUB1 fuses in the under hood fuse panel.
Custom Fit Sun Shade for the Yaris Liftback tomato General Yaris / Vitz Discussion 24 06-29-2009 01:18 PM
Lower Mainland Yaris, Echo, Fit, Mini, meet mojoyaris Canada 24 11-02-2008 01:16 AM
What aftermarket exhaust will fit the Yaris Sedan? dngz Performance Modifications 2 10-02-2006 01:41 PM
