Old 05-01-2011, 10:26 AM   #1
stephen67
Drives: car
Hi
Weapon-R Dragon Air Intake Systems come with 6061 Aluminum components TIG welded and are CNC Mandrel bent for peak performances of maximum horse power and best torque gains. Each of Weapon-R Dragon are fine tuned to assure perfect attachments and fittings, precise measures for the tube length, diameter and bent radius, maximum air intake capacity and unobstructed air flow with maximum speed. The air filter is protected perfectly with the dense and high quality Poly Urethane Foam. Weapon-R improves the air flow more than 80%. It assures better dirt filtering with the foam filter than the cotton filters traditionally used. The filter of Weapon-R Dragon air intake is designed in CAD (Computer Aided Design) and has a flow benched tested velocity stack. The system offers high performances with the increased airflow.
Weapon R dragon intake
stephen67 is offline
Old 05-01-2011, 10:26 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by stephen67 View Post
Hi
LMAO this has to be the most random first post I've ever seen.
Bluevitz-rs is offline
WeSellCarParts.com // Weapon R Yaris Dragon Air Intake WeSellCarParts WeSellCarParts 19 12-27-2008 09:31 PM
Weapon R intake? AlphaFox Performance Modifications 77 11-14-2008 05:10 PM
weapon R dragon on my car (vid) BrazdonW Performance Modifications 22 07-29-2007 12:14 AM
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
