Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-02-2011, 08:10 AM   #1
syntax
syntax's Avatar
Originally Posted by rye7jen View Post
Mga kayaris, question, pag naka-idle ang sasakyan ko, may naririnig ako na galing ata sa engine bay na parang tunog fan na maingay, parang helicopter ang dating. nagkakaroon nun habang idle tapos every other minute meron. Natural lang ba ito?
rye na check mo na ba ang coollant level mo? automatic na mag on ung fan para sa radiator, kapag nag iinit sya, ganun din si shadow kapag naka idle ( observed it already 3 times dati) 1 year na ang flint micas natin, time to flush and refill ng collant. i think normal lang un, paki correct lang po if i'm wrong salamat
Old 05-02-2011, 08:38 AM   #2
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
@ rye, yes syntax is right there... check your coolant level? tag init na ngayon...
marble_bearing is offline   Reply With Quote
Old 05-02-2011, 09:49 AM   #3
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
kung i-drain mo rin lang ung coolant mo, i advise na bumili ka rin ng radiator flush(available @ saco). Flush the radiator and refill the coolant. Either ung Pre-mix Toyota coolant or AC-Delco..Hinde yung kulay green na nabibili sa gas station ng 15 rial.
HiH
ricepower is offline   Reply With Quote
