Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-02-2011, 10:11 AM   #1
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax/ricepower, thanks sa tips, might try that coolant flush pag sweldo na. Alam ko si joni nagflush na rin ng coolant niya.
@marble, matabang la cguro katon unkakapoy la.
rye7jen is offline   Reply With Quote
Old 05-02-2011, 10:17 AM   #2
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
hwag lng sadiki ha kasi distilled din yun?
naani agmo nacontrol ta abwek lay luganan mo...
marble_bearing is offline   Reply With Quote
Old 05-02-2011, 02:14 PM   #3
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
kaya mo yan iflush ma-isa kaysa bayaran mo ung radiator shop at ganun din ang process na gagawin using radiator flush..
Better check the instruction provided by the radiator flush..
Ung akin nun is the ff:
*drain the coolant
*put fresh water and mix with the radiator flush - check the ratio
*start and rev the engine for 5 minutes..cool the engine and drain the radiator
*put fresh water
*put new coolant preferably pre-mix(kulay fenk)
HiH
ricepower is offline   Reply With Quote
Old 05-03-2011, 03:15 AM   #4
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
*drain the coolant
*put fresh water
HiH
Will take note of this.
Ricepower, ilan oras pala inabot sa pag-flush ng coolant?
Old 05-03-2011, 03:14 AM   #5
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Hahaha! mairap la man.
Old 05-02-2011, 05:40 PM   #6
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
@rye, di pako nag-FLUSH ng coolant ko, nagdag-dag lang ako last tym. Remember sa kamsa2x, nagaalok ako kung sino may gus2 at sasalinan ko. kulay pula sya original from toyota.
jonimac is offline   Reply With Quote
Old 05-02-2011, 07:32 PM   #7
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
eto ba ung 5SR per refill or top up wahahaahhaha
pre kulay fenk ata un
syntax is offline   Reply With Quote
Old 05-03-2011, 03:13 AM   #8
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Oo yan nga yung sabi mo dati, akala ko ng nag-flush ka na ng coolant mo.. any future plans? Sabihan mo lang ako.
