Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-02-2011, 02:14 PM   #1
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Originally Posted by marble_bearing View Post
hwag lng sadiki ha kasi distilled din yun?
naani agmo nacontrol ta abwek lay luganan mo...
kaya mo yan iflush ma-isa kaysa bayaran mo ung radiator shop at ganun din ang process na gagawin using radiator flush..
Better check the instruction provided by the radiator flush..
Ung akin nun is the ff:
*drain the coolant
*put fresh water and mix with the radiator flush - check the ratio
*start and rev the engine for 5 minutes..cool the engine and drain the radiator
*put fresh water
*put new coolant preferably pre-mix(kulay fenk)
HiH
ricepower is offline   Reply With Quote
Old 05-03-2011, 03:15 AM   #2
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
*drain the coolant
*put fresh water
HiH
Will take note of this.
Ricepower, ilan oras pala inabot sa pag-flush ng coolant?
rye7jen is offline   Reply With Quote
