wat r things to do when changing from 15 to 17?
what adjustments should I make?
tires are 205 45 17 with 17-7.5 -- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
there should not really be anything to adjust, but get your alignment checked just in case!
alignment it is!
-- Blen
I'll post pic when I get them this week...by like around thursday or friday...how much is it to have sum1 install them for me? what is the price range so I can go hustle them down for a lower price.
-- Blen
#5 | |
I always shop around for someone who mounts aftermarket wheels everyday. Having the job done correctly and rolling away with no scratches or gouges on my wheels means more to me than price.
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
are you dropped? or on stock springs? im runnin a 17x7 wheel with a +42 offset. im on 205/45/17 tires and with tanabe nf springs i have minor rubbing on good sharp dips, i think this could be corrected with a stiffer set of aftermarket shocks....
your case may be different but im just throwing up the warning. i think i may go with a 205/40 along with the shocks and i know i wont have any problems.....
No drop here...mine are 42 offset too.
Will I rub with no drop? -- Blen
Q(','Q)
I was told that from going to 15 to 17 an aliment is necessary. Something about adjusting the front toes.
My question is out of place but how do you find the offset to your rims? Are they listed on the rims themselves? |
The Beautification of Car
i heard that when you do balance and rotate you need to bring it to a place that they do high speed balance and rotate it's cost around $100 dollars for that. So when you ride at high speed like 80 and up your car will not move around or kindda like jipperryy ( shaking) is it true?
you may look at the hunter gsp 9700 balancing system ck their web site i understand that tirerack a discount tires use this and is considered one of the best my discount store balanced my yaris an has no vibration at any speed also they offer free spin balancing an rotation for the life of your tires may wk for you
#11 | |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
no alignment is needed when changing wheel/tire size... Changing your wheels in noway magicly adjust your tie rods... and if you are wanting to run a 7.5 wide wheel I would go to a 215/40R17, unless you like the stretched look then go 205's. Also with a +42 offset and a 7.5in wide wheel you most likely will rub,but only on a full lock turn.
Alright I need a newb guide to tires and what not. Like the sizes and what all they mean and what not. Cause I read all this on here and really have no idea what everyone is talking about. Is there such a post already if not could someone help me out a bit. Thanks :)
#14 | |
http://dansides.justgotowned.com/ -- Blen
#15 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Here is the spreadsheet I use to play with sizes. it SHOULD oughta be self-explanatory, but feel free to ask.
Steve |
#16 |
Yes teacher will try and do better next time just doing it in a hurry ... I was THINKing most people know where the .... ,,,, ???? //// """" should be. From now i will do better . I think i will go set in time out now.
| Things you would like to see? | Chaad32 | General Yaris / Vitz Discussion | 46 | 04-15-2009 08:01 AM |
| Changing Headlight Bulb Tutorial | RSboyz | DIY / Maintenance / Service | 29 | 03-15-2007 01:35 PM |
| Are you changing your oil at 5k mile interval recommended by Toyota? | Yaris_Fan | DIY / Maintenance / Service | 24 | 01-30-2007 11:54 AM |
| Wat is different between DF 210 and Nf 210 springs and which one it better?? | mariosuper | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-16-2006 01:39 AM |
| Changing to 60/40 seats? | NickNickNick | General Yaris / Vitz Discussion | 1 | 05-14-2006 04:08 PM |
