keep it covered
Free Mustache Rides
my friend had NOS in his old 85 5.0 and it was fun. but im telling you, get the turbo kit. imagine the day you run out of NOS and it will be a day or two til you get to refill it, but then a scion pulls up beside you...you no longer have advantage. where as turbo kit, it's always there for you. Not to mention how sweet blow off valves sound.
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
#4 | ||
I ain't even mad
Precisely or even behind my sub :b
Not quite a noob
Dunno if you can see this page but:
http://www.revscene.net/forums/searc...archid=2331889 If you can't read it, I suggest registering there and searching the police forums for legality issues. |
#6 | |
I ain't even mad
EDIT: Read up abit, aslong as it is 10-20lbs I can apparently have it. Must be hooked up aswell and aslong as I'm not breaking the speed limit I can spray all I want. Let's consider this a success everyone, will I be the only one on this forum with Nitrous?
![]() Last edited by .Kevin.; 05-07-2011 at 02:14 AM. |
Not to scare you off of using it, but I was in a toyota dealer a few years ago talking to one of the techs and he showed me some exhaust valves he had just pulled from a customers car. It looked like someone had cut a slit into them with a cutting torch! No joke. Don't really know any of the other details, all I know is that it was from the NOS.
NOS is an Oxidizer similar to Oxygen. It makes the fuel burn WAY hotter, that's where the extra power comes from. But that's also where the danger in melting down your engine is. Just a warning. |
#8 | |
I ain't even mad
Good thing I always run premium anyways :)
I ain't even mad
I thought NOS was cold air? It is not even combustable so what made you assume that NOS did that.
It's an oxidizer. It promotes burning just like oxygen.
Maybe you should be doing a litte more research on HOW the system works before you kill your motor. |
It might also be in your interest to run an A/F sensor and larger injector for additional fueling. Might even need a FMU.
#13 | |
Bluevitz-rs, you left out an important detail.
N2O also provides a cooling effect, an important factor. It's not just the oxygen atom that is useful with this system. I can't explain it any better (from http://paultan.org/2006/02/23/how-do...-oxide-work/): Quote:
I ain't even mad
Meaning everything should be fine aslong as we don't shoot too much
^ as long as the kit is spraying fuel with the NOS in the proper proportions then you should be fine.
And I would avoid hitting the rev limiter like the black plague for risk of running lean. |
I ain't even mad
well Yaris usually rides at 2.5k rpm so if I go with wet spray I figured launching it then would be about right in the rpms range
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
I've been dealing with nitrous for years (since 2001). The number one thing that you will need before you even purchase the nitrous kit is an AEM wideband O2. Install that first and check where your fuel ratio actually is. Safest way to run nitrous is with a wet system, the dry system will hit harder but this setup is usually the cause of all the horror stories you hear from people. People spray too much nitrous without the appropriate fuel and then everything goes boom. Start out small with a 50 shot jet and work your way up. Just be sure to monitor your air/fuel gauge and be sure that you have enough fuel before you up the jets.
My friend has a tC and we've been told countless times on numerous forums and from many people in person that the motor can't handle more than a 75 shot. We started out with the 75, saw that we had enough fuel, took it to 100, saw we still had enough fuel, jumped to 150, still had enough fuel, now we're at 200. If we run 110 octane we can go further but that stuff isn't cheap lol. We only run the car on 93 octane unless we have a big race. Just make sure that you monitor your gauge while you're spraying. Also, you can safely run one jet lower on the fuel than the nitrous. If you buy a kit it will give you recommended jet sizes for each shot, you can safely run a 50 shot nitrous jet with the 35 shot fuel jet (I forgot the actual jet numbers and such, sorry). NX has the most complete kit if you want something relatively plug and play. Not sure what they have for the Yaris, you may just have to figure out the fuel fittings and such but everything is "should" work pretty straightforward. I believe "blacksandiegovitz" is running a nitrous setup currently, you might want to get a hold of him for better/reliable information on safety levels for the Yaris. Let us know how it all works out for you if you end up running nitrous. |
| Custom Intake manifold/w 1zz tb / direct port nitrous | blacksandiegovitz | Items for Sale by private party | 28 | 11-23-2010 08:57 PM |
| Nitrous - Safe Shot System - a safer alternative | fuji | Performance Modifications | 15 | 04-17-2009 04:24 PM |
| Talked to my mechs about nitrous. | staticorex | Performance Modifications | 29 | 10-26-2008 04:33 PM |
| Nitrous Oxide Systems, Yaris on the Bottle | CASTREX | Performance Modifications | 20 | 07-15-2007 10:40 PM |
