Old 05-05-2011, 06:21 PM   #1
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
auxmike - Just curious as I'm guessing I'll run into this issue at some point too. Did you DIY and was it cramped getting the pump in and out? Doesn't appear to be whole lot of clearance in that area.
Old 05-08-2011, 04:25 PM   #2
auxmike
auxmike's Avatar
Yeah, I did DIY.
In order to get the old pump out I had to put a 4ft. pry bar between the engine and the frame side. Then I pulled real hard as I slid out the pump. It did put 2 dents in one of the A/C tubes though. Rested the bar on the center bolt of the crank pulley. I did this because I did'nt want to start lowering the engine and causing more problems...
