Old 05-08-2011, 01:01 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
installing spacer behind the hub is pretty simple process just make sure 1. grease it up before installing. 2. might want to shave the spacer and make a groove so you can easily pry it off incase you need to remove it other wise its a bitch to take off.. i was rubbing so i had to remove it...
WTT: 13mm hub spacer for a 10mm hub spacer. marlondog Items for Sale by private party 0 11-18-2010 04:42 PM
anyone knows if wheel spacer can be placed behind the hub??? jackrabbit Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-02-2010 06:41 PM
R.I.P. to the original hub spacer test car :( Tamago Photo-Video-Media Gallery 20 09-01-2009 12:49 PM
DIY aftermarket steering, hub, quick release install AlainMikli DIY / Maintenance / Service 17 07-20-2009 06:01 PM
Penguin Garage Rear Hub Spacer Raffle!! Penguin Garage General Yaris / Vitz Discussion 27 06-30-2009 01:05 AM
