Old 05-15-2011, 12:04 PM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
When I first installed my 2azfe injectors I had similar problem. You will need to run negative numbers in your map, when runing without boost. I am at -28% in my fic map. you will need to experament a little to see what runs best with your injectors. Do you have a wideband o2 sensor? Its a great help when tuning. I tune for 14:1 afr when driving normal and 11.5:1 when in the boost.
pimp my yaris is offline   Reply With Quote
Old 05-15-2011, 12:31 PM   #2
Nixk
Nixk's Avatar
Drives: blue 2001 echo
Send a message via MSN to Nixk
i have a wideband, and i tried to put some negative values in my map and my car didnt take it i had to stop on the side and undo the changes i made
Nixk is offline   Reply With Quote
