#1243 |
Roadrunner Jr.
Do you want to make that enclosure or do you want us to? That's the hard thing for you...it's a T/L enclosure. Right now we're still playing around with how to get these little woofers to give BIG impact. They sound spectacular but the output isn't as much as we'd like.
It's simply not a slap it in and let it go woofer.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#1244 | |
I will supply .35 cubic fit with 2" Diameter 16" long vent , like HAT shows in their website, as a starting point and see what happens? I'm sorry for the slow return, I got a new (temporally job in the IT area) with lots of commute, and some other photo projects, keeping me very busy and no time for my hobby/passion. D.
. CLA 250, 4MATIC |
#1245 |
Roadrunner Jr.
Job and family come first bro!
Like I mentioned in XBR's post, I've got a GREAT solution to IB the L6's. Check this out: You know the plastic insert mounts that the styrofoam goes into on our floor boards? ![]() Use a flat blade screwdriver or panel popper and pop that bad boy out. ![]() ![]() ![]() It gives is a 10"^2 aread for the L6's to vent! WOOT! Take out your kicks, mark the area where that hole is, make the cut in the bottom of the pod. Before you put the pod back in, put some polyfill into the hole. It's a crumple zone that remains more dry than the doors do. I'd place a thin gasket around the hole and replace the kick pod. The mid bass response should be remarkable at this point, especially versus a sealed enclosure. ...and let the magic happen!
#1246 |
Yes, I've been there before! and I was going to vent that way too, but since the idea of an I6SW would go on the floor, the kick panels (right side) would have to move out to leave space for the little woofer, a give & take so I gave up kick panels, and the L6's will go in the OEM door locations.
Lets get all the info/photos for your diagram with new equipment and we'll finish it up. D.
. CLA 250, 4MATIC |
#1247 |
Roadrunner Jr.
I don't see any pics of the Voce amps out yet. The Bit One is a different story. You can Google images for that.
#1248 |
Did any body notice some new cars have tweeters at the A-pillars and are kind of aiming at the center of the windshield? away from the listeners? I know Sqcomp has his tweeters that way, I did try to aim my Mids and surprisingly it gets a very good Image and depth specially the vocals right in the middle of the dashboard, but the with of the stage compromises a little bit... I'm realizing that instead of dealing with bad reflexions from the windshield they are trying to take advantage.
![]() Working on some new rings for my Mids, and trying to fit the grill that comes with the HL-70 for a different look... I just want to use the middle part witch is Silver, I'll take my own pictures tomorrow... ![]() D.
. CLA 250, 4MATIC |
#1249 |
Roadrunner Jr.
It's something that can be worked on for stage width...I know how to improve the stage width while even improving depth from the way I have it now. The thing is, that proverbial next step is a BIG one. If I wanted to keep the pillars similar to how they are now, I'd simply shrink the mids down in there more since I'm using a neo magnet speaker. I MIGHT aim them more on axis next time. I'm talking only something like 15 degrees more on axis than they are now.
#1250 | |
Are you planing on redoing your front stage? in a very different way? D.
. CLA 250, 4MATIC |
#1251 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() D.
. CLA 250, 4MATIC |
#1252 |
Roadrunner Jr.
Is that balsa wood you're using for the surround on the ring?
#1253 |
It's 1/32 Plywood, and I made a sandwich of 3 layers, very strong, very light and small. My idea is to make it as small as possible to sink the baffle in the A-pillar.
D.
. CLA 250, 4MATIC |
#1254 |
A little bit of progress... It's ready to cover, also I did aim the tweeter in the same angle as the Mids... so far sounds pretty good.
![]() ![]() D.
. CLA 250, 4MATIC |
#1255 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
#1256 |
And Derick, please tell me you going to remove that speaker from the ring before you start schlepping fiberglass or whatever around that thing, right??!! LOL
#1258 | |
I still have to get the other side at this level, then I'll drive around a few days to make sure the aiming is "ok" for me. Actually I'm going to use CA+Kicker over speaker grill to create the shape, again, keep it light but strong. (that's from r/c airplanes, every thing has to be strong but keep it light so still flies) D.
. CLA 250, 4MATIC |
#1260 |
OK, I just got a RTA...!
How do I use it? any body knows a link with a "How to use RTA in a Yaris"? LOL D.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
