Old 05-20-2011, 07:13 PM   #1
regal
Drives: 09 Yaris 3 Dr White LB
After 2 years with my Yaris I have one complaint
It needs a six speed manual transmission, it just pises me off reving too high at 65mph wasting gas. I plan on keeping this thing 20 years as I am just don't like hybrids (due to long term maintenance issues.)
As anyone found a bolt in 6 speed? Will the new Yari's have a 6 speed?
regal is offline   Reply With Quote
Old 05-20-2011, 07:14 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
someone did a swap on his tranny..try to look it up..
Old 05-30-2011, 11:41 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
That would be me...
The thing is, I'm getting better millage now with the 6 speed even though it revs HIGHER than the stock transmission. @100km/h it's now turning 2950rpm instead of 2600.
Process that one
It's not about revving lower, it's about running the engine more efficiently. And for the most part in the city I don't need any more than 2000-2500 in any situation because the gears are SO close together.
But if you're inclined to swap out an echo 3.5 F/D into the yaris, I have my old tranny guts for sale.
Old 05-20-2011, 11:28 PM   #4
brg88tx
Drives: 07 Yaris Sedan, Auto
i can't complain, i still get 38 mpg with the cruise set on 78 with my automatic sedan.
brg88tx is offline   Reply With Quote
Old 05-21-2011, 08:44 AM   #5
Bredayaris
Bredayaris's Avatar
Drives: Toyota Yaris 1.3 vvti cvt
Here in Europe you only get the 1.0 vvti with a 5 speed transmission.
The 1.3 and 1.8 petrol and 1.4 diesel have a 6 speed transmission.
Bredayaris is offline   Reply With Quote
Old 05-21-2011, 01:33 PM   #6
Hershey
Go in between with a 5 speed automatic or a C.V.T.. Could bump up the mileage . Better coasting . Notice this with the 2011 FIT with the 5 speed auto . We test drove a SX-4 wagon all-wheel drive with a 6 speed manual and another with the C.V.T. on the same roads / streets . The C.V.T. would coast better .
Old 05-21-2011, 04:42 PM   #7
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
how high does your revs get in 5th @ 65mph?
you sure your in 5th gear not 3rd?
maybe time for you to replace the clutch
OTA'sTOY is offline   Reply With Quote
Old 05-21-2011, 06:42 PM   #8
NZ-FE Vios
Only Timing Chains
Drives: 09YarisSedan, 94Truck22re
In 5th at almost 70, I'm floating 3k rpm, 65 is about 2800rpm. Which is incredibly too high. I don't understand why Modern MTs don't always have a 6th, especially if one is already in production.
As previously eluded to is that our American engine (nzfe) is the top of the line n/a in Europe, they also have the sales and consumer base to have complaints refine the manufacturing. I believe it is the top selling car in its range in G.B. since 1999. Also Europeans sell so many more MTs and would hurt sales if it was only a 5spd. Why would Toyota have cared here in the states with a hugely disproportionate AT to MT sales, when the 5 to 6speed saves them in the long run. (the echo was great but didn't sell well in the states unfortunately)
I would be leery of a CVT they can shift faster than a human but have enumberable moving parts in compared to a MT. Toyotas CVT may be nicer but I prefer a standard.
The clutch really should not have anything to do with RPMs at speed.
NZ-FE Vios is offline   Reply With Quote
Old 05-21-2011, 08:40 PM   #9
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
My 01 Echo had a lot taller final drive ratio. I hated the Yaris transmission almost immediately.
Old 05-22-2011, 10:24 PM   #10
vector9mm
Drives: blue 08 hb
[QUOTE=Flipper_1938;581790]My 01 Echo had a lot taller final drive ratio. I hated the Yaris transmission almost immediately.[/QUOTE
When the Yaris came out I noticed that the rated mpg was less than the Echo's. I think the last year Echo was 43 and the Yaris was 40 highway. These are before EPA changed their rating system. This explains a lot.
vector9mm is offline   Reply With Quote
Old 05-21-2011, 09:07 PM   #11
NZ-FE Vios
Only Timing Chains
I haven't done any research but has anyone changed the final gear in the Yaris at the same time as clutch? Is there a different 5th gear that can be swapped in? I would think it would be cheaper than doing whole trans and have a similar affect as 4th and 5th gear are close in ratio
Old 05-21-2011, 10:40 PM   #12
enviri
enviri's Avatar
Drives: 2010 Yaris
3k rpm @ 70 is too high? I've owned a good amount of japanese cars and i just find it being normal?
Old 05-22-2011, 11:01 AM   #13
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
Yep.
I recall my 72 Subaru GL would show 3,460 RPM's @ 70 MPH. It had a 1.267L EA - 62 engine. Albeit, with a 4 Spd manual.
DMZ is offline   Reply With Quote
Old 05-23-2011, 11:57 AM   #14
Yaristeve
Drives: 3-door hatch
I agree. These cars only have a 1.5l engine. If you think the Yaris is bad, my IS300 5-speed, with the 3l, 2JZGE inline 6, unbelievably revs even higher (about 3300rpm @ 70 in 5th gear) than my Yaris 5-speed. But that low (numerically higher) rear end gives it a lot more pep than 200hp really should. But mileage really takes a beating, the best I ever got out of it is 30MPG at a steady, cruise controlled, 70MPH...
Old 05-21-2011, 10:50 PM   #15
regal
Roughly guessing there is at least a 5gp boost if a 6th speed dropped the rev's to 2000ish. My guess is the engine doesn't have enough torque to be "safe" on the highway, probably some stupid safety regulation put in place to keep the mid east oil rigs pumping.
Old 05-21-2011, 11:20 PM   #16
NZ-FE Vios
Only Timing Chains
A friend had mentioned something along those saftey lines in re to civic and that's a 1.8 with a bit more power and torque. The gov also most likely doesn't want us to be able to cruise near 90mpg at 3krpm
Old 05-22-2011, 09:15 AM   #17
Brianr4
Drives: 2008 Yaris 3dr Hatchback
When I installed my tach my first thought was wishing I had a 6 speed to drop the rpm's down.
We would be looking at close to 50 mpg!
Brianr4 is offline   Reply With Quote
Old 05-22-2011, 11:58 AM   #18
bronsin
bronsin's Avatar
A 6 speed transmission is NOT necessarily better for mileage. It all depends on the ratios. If 5th and 6th are numerically the same a six speed will use MORE gas! You have one more gear to accelerate in. The ideal would be a three speed with numerically identical 3rd gear to a five speed 5th. It would work here in flat NJ but probably not in hilly country.
SIx speeds and even five speeds are stupid consumer driven idiot inspired devices. Auto trans are similiarly going through the idiot process of more and more speeds.
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
